LED’s & PCM’s
Old Jul 4, 2018 | 02:23 AM
USCPsycho's Avatar
Default LED’s & PCM’s
is it at all possible that aftermarket LED replacement lights for both the interior lighting and license plate lights could fry or affect a Mazda 6’s PCM?
Old Jul 4, 2018 | 06:15 AM
Unlikely, however, the BCM - Body Control Module - can be affected due the change in power consumption / load.
Old Jul 4, 2018 | 09:23 AM
espnews's Avatar
I'm not going to argue but I was under the impression the LED bulb draws less voltage than the standard bulb. I don't see how it could have a negative effect.
I do know that there are many owners of the Mazda 6 that have replaced the stock bulbs with LED's and there have been zero issues. It is important that the right ones be used.
https://www.diodedynamics.com/?utm_s...paign=research
Old Jul 4, 2018 | 11:29 AM
USCPsycho's Avatar
Understood. I’m just trying to figure out why I had to replace my oem PCM and then 200 miles later have to replace it again. It’s the only explanation I have as I put those LEDs in a day or two before.
Old Jul 6, 2018 | 05:18 AM
The BCM relies on a certain voltage/load, fitting LED's lowers the voltage use/load & this can confuses the BCM. Also the can sometimes spike the BCM.
I'm no expert in electronics, just adding what I know when I can.
turboturney
Jul 23, 2023 12:51 AM
UseYourNoggin
Aug 21, 2015 02:34 PM
UseYourNoggin
Jan 25, 2014 10:15 AM
toonzer
Feb 18, 2010 01:20 PM
Quasimodo
Dec 8, 2006 02:30 PM
