automatic transmission range sensor/ neutral safety switch
Old Aug 4, 2022 | 03:37 PM
djernie's Avatar
Default automatic transmission range sensor/ neutral safety switch
I have a 2006 mazda 3. I recently had the transmission rebuilt and since then this problem started. The mechanic put in two neutral safety switches and the problem of the car not starting in park or neutral continued. I would have to move the shifter around from park to neutral and back again then it would start. I could even move the cable by hand after taking it off of the shifter and push the cable forward enough and it would start. So i adjusted the cable and attached it back on the shifter it worked for one day. So i just bought a new cable and a new neutral safety switch and took it to a transmission shop and let them put it on for me. Well it worked for two days and then i had to move the shifter from park to neutral and back to park and it would start. Then I could move it to the right as if i was going to move it to drive and it would start. Now it wont start at all no matter where i move the shifter. Just wondering if any one has any ideas that i could try. Is something blowing the neutral safety switches? I am going to buy another Neutral safety switch and put it on and see if it will start, before i take it back to the transmission shop and ask for their help in getting this solved. Any ideas would be appreciated. Thanks
brp223
Aug 4, 2022 12:51 PM
jwehrheim
Aug 28, 2020 04:17 AM
317Highlander
Feb 2, 2018 03:04 AM
Da hamma
Jul 30, 2017 09:47 PM
mommamouse411
Nov 9, 2010 08:58 AM
