Keyless entry
Old Aug 23, 2007 | 02:14 PM
Skillet's Avatar
Default Keyless entry
For sometime now when i lock the doors with the remote or even with the key after a little while the horn starts to blow like i pressed the panic button. It doesnt do it all the time but more times then none. Does anyone have any ideas of what may be causing this. I'm to the point where i am fixen to disconnect the horn and be done with it. its a 2000 mpv.
Old Aug 22, 2008 | 12:42 PM
mtapley's Avatar
Default RE: Keyless entry
Does anyone have directions to program a 2000 mazda mpv? I have contacted the dealership and they want $120.00 which I find rediculas for such a small task.
Old Jul 29, 2009 | 06:33 AM
mazdi_'s Avatar
If you need to just order the instructions please check our website at
http://www.carandtruckremotes.com/pr...tructions.html
Old Jul 29, 2009 | 06:57 AM
savo's Avatar
I do not think that your problem lies in your remotes. More than likely you have a factory alarm. Locking the car with the key or the remote should enable it. What is happening is one of your alarm triggers is failing. Possible due to heat. Heat can cause metal to expand. SO in the hot summer one of you alarm sensors is expanding and your factory (or aftermarket) alarm is trigger to sound the horn.
You might want to take it to a dealer and ask them IF you have a factory alarm. If you do they can scan the GEM (Ford calls them that) for which trigger has been setting it off.
I know in the Taurus world it is normally is either the trunk or hood anti-theft switches.
Good luck
98Millenia
Apr 3, 2021 07:23 PM
jiggaman
Jul 30, 2006 04:24 PM
srozycki
Jun 19, 2006 12:45 PM
AthosMR
May 21, 2006 11:02 PM
jruddy
Apr 20, 2006 10:38 AM
