2011 CX-9 nav screen Program cannot be read
Old Jul 25, 2021 | 09:51 AM
Billquig's Avatar
Default 2011 CX-9 nav screen Program cannot be read
After a dead battery issue on my ‘11, I now have the message “Program cannot be read. Please consult to a dealer.” The system is non functional as a result. I’m told to reinsert the SD card. I have looked everywhere and can’t find anywhere for an SD card and the manual makes no mention of it. I’ve also been told to use the map dvd from the glovebox to reboot it. When I insert the dvd, it clicks for a while then ejects it. There is a slot behind the display screen marked for nav map dvd only. This is the one I’m using. I’ve also been told to disconnect the battery negative cable, turn on the headlights and hold the brake for one minute. Then reconnect the cable and it will reboot. I have tried that six or seven times and it still will not reboot. The system worked fine before the battery issue. Has anyone had this issue on a 2011. I have seen a lot of people with the same issue on different years who correct it very easily but none of those things seem to apply to this model. 2011 Touring.
Thank you in advance.
Old Oct 9, 2021 | 05:27 AM
Mummaxofx3's Avatar
I have the same problem. Did you ever solve this?
Old Nov 17, 2024 | 06:13 PM
robyndowd's Avatar
Default 2012 CX9 nav screen program cannot be read after new battery installed. We’re you abl
I have the same problem. Wereyou able to fix?
Alain Lanyau Rodriguez
Feb 6, 2025 05:36 AM
Lee Hayward
Aug 31, 2024 11:16 AM
rromanczyk
Jan 4, 2023 04:31 AM
Billquig
Jul 25, 2021 09:27 AM
