front struts and rear suspension
Old Sep 7, 2023 | 07:22 AM
hotchocalate2022's Avatar
Default front struts and rear suspension
Well it looks like its about that time my ride is a 2014 cx5 grand touring and she has about 108,000 the ride has been kinda bumpy and i hear clunking noise almost every time I hit a good bump . i would like to attempt to replace the front struts my self . my mechanic told my that my sway bar links could be causing the clunk should i replace these as well ? I need some recommendations on a good place to buy them online I have used rockauto in the past I dont' want to spend a ton of money but i don't want to buy the cheapest ones either any idea's gonna replace the rear as well the sway bar links in the back already came apart so I definitely need to replace those .
Old Sep 7, 2023 | 08:54 AM
I'm not going to be much help.
There are a host of places to get what you are looking for and people here will chime in on their favorite places and products.
However, they are all based on personal opinions, driving habits and the definition of a "ton of money" which differs with everyone based on their income.
First you need to decide what you are going to replace and how much you want to spend to do it.
Once you do that you can selectively choose the supplier who best fit your needs.
I can tell you that OEM or OEM quality-based parts will likely be your least expensive as any good performance replacement systems will be more expensive.
Old Sep 7, 2023 | 10:21 AM
K.I.S.S.= keep it simple stupid
If it is just a run of the mill "mechanic" you trust, then go to Rock Auto and get your parts and give them to the mechanic to install. Don't forget after that many suspension replacement parts you will need an alignment.
Rock Auto parts have great description on most of them so you can get a idea of what to expect. But for simple replacement front struts, rear shock and sway bar bushing it is pretty straight forward for you MAZDA model and the miles on it and what you use and have used it for so far when choosing parts.
Old Sep 8, 2023 | 06:14 AM
I live in the northeast and most of the roads I travel are in good shape , I understand that I will need an alingment if If I do the front struts but wondering if I also replace the shocks in the rear does that mean I need a rear end alingment as well ? this is an a wheel drive vehicle 2014 mazda cx5 grand touring edition
Old Sep 8, 2023 | 02:48 PM
No one can answer this....it must be checked either physically doing the measurement (very hard and needs experience knowing exactly how to manually do this) and a new piece of chalk tape measure and some string.... hahahahaha.. or on an alignment rack.
Jmazda2011
Apr 11, 2018 02:22 PM
gunkl
Aug 26, 2011 02:51 AM
swaybar
Jun 2, 2007 06:58 PM
Spaz218
Feb 24, 2006 11:03 PM
