suspension
Old Jun 2, 2007 | 11:34 AM
swaybar's Avatar
Default suspension
Help....suspension...
I've got a '95 Protege LX with around 100,000 miles on it and I've gone through three sets of swaybar links and they're worn again....causing clattering suspension over the slightest bump. Are these designed to wearout so more money can be made later on or what!? Has anyone else gone through so many swaybar links!?
Old Jun 2, 2007 | 06:58 PM
babyhuey's Avatar
Default RE: suspension
You are refering to the links that connect the sway bar to the struts? Sounds like way to many sets of links. Do see failures on them but not that often unless you are having to replace every 80-100k miles. Would check the front suspension over carefully to see if something else is also worn out, namely the front struts. Very weak front stuts could but a very large strain on the links if they are not dampening the suspension movement over bumps.
Push2Drop
Sep 3, 2011 03:44 PM
Djshakes
Oct 3, 2005 06:30 PM
cvillareal
Aug 5, 2005 04:02 AM
millyman
May 2, 2005 09:39 PM
momazda44
Apr 11, 2005 11:07 PM
