2016 CX-5 drivers HID and highbeam both out
Old Nov 25, 2023 | 04:57 PM
thompsoncd's Avatar
Default 2016 CX-5 drivers HID and highbeam both out
Both the HID and highbeam on the driver side is out, and it seems unlikely both would happen to be out at the same time. I’ve checked the fuse and the relay, both are good.
Any thoughts as to what could cause this? I guess there’s a slight possibility it is a coincidence that both are out at the same time.
Old Nov 26, 2023 | 06:16 AM
If fuse and relay are okay, then it's wiring or bad lights.
To check/test either you need to basically remove most of the front-end plastic to reach the cable plug end and/or the lights.
Old Nov 27, 2023 | 09:20 AM
thompsoncd's Avatar
Default Thanks!
Thanks. I’ll replace the high beam, since that’s easy, and see if it’s just a coincidence that both are out.
thompsoncd
Nov 25, 2023 01:40 PM
jonf49
Sep 12, 2022 11:58 AM
jonf49
Jul 3, 2022 04:43 PM
jonathan.rubin@sbcglobal.net
Sep 3, 2016 11:48 PM
JJN066
Oct 13, 2006 03:16 PM
