torque for transmission mount?
Old Jul 12, 2016 | 01:42 PM
playkool247's Avatar
Default torque for transmission mount?
hello, i have a 2008 mazda3i manual with 130,000 and wanting to change the transmission mount but cannot find what is the torque spec.
what is the transmission mount torque for the one under the battery? the four side screw and the one in the center.
Another question: the torque for the motor mount (under the car). Some say 54-66 ft-lb for the 2 bolts for the mount and the 3 bolts for the bracket that mounts to the transmission are 70-85 ft-lb. is this right?
thank you
Old Jul 13, 2016 | 06:23 AM
There are two different centre bolts used by Mazda, there may be a "8" or "10" on the bolt head.
"8" 83-113nm
"10" 130-152nm
The four corner bolts are 44-61nm
Old Jul 13, 2016 | 11:55 AM
Default thank you for the info
"8" 83-113nm
"10" 130-152nm
Thank you for the info. What about the one under the car. Is it sound right, 54-66 ft-lb for the 2 bolts for the mount and the 3 bolts for the bracket 70-85 ft-lb and should i use any thread lock blue or red on these as well?
Old Jul 14, 2016 | 12:30 AM
The bracket that bolts to the gearbox is 65-75nm
The bolts thru the actual mount can varry between cars, refer to picture.
Tightening torque
A type: 72.6—90.9 N·m {7.5—9.2 kgf·m, 53.6—67.0 ft·lbf}
B type: 104.2—132.6 N·m {10.7—13.5 kgf·m, 76.9—97.8 ft·lbf}
mig25
Jun 15, 2024 04:22 PM
santa6
May 6, 2011 04:43 PM
arnie
Oct 19, 2008 10:42 PM
klutch_3
Oct 18, 2008 07:58 AM
bdubbs84
Jan 20, 2007 01:31 AM
