Rack and pinion replacement 2009
Old Jun 30, 2020 | 09:03 AM
Zoomzoomzoom3's Avatar
Default Rack and pinion replacement 2009
Does anyone know how to get the rack and pinion out of an 09 Mazda 3? I’m having a hell of a time figuring out how it’s supposed to slide out. Any insight is appreciated!
Old Jun 30, 2020 | 09:05 AM
You need to drop it out along with the subframe. Then seperate it from the subframe.
Old Jun 30, 2020 | 09:32 AM
Ok thank you! I’ll give it a shot!
Old Jul 1, 2020 | 10:04 PM
alright got just about done taking the subframe out and the top bolt on it will not loosen nor tighten any further than this, it just spins either way and does not go in or out. I’ve tried putting pressure on the bolt with a pry bar and turning but it hasn’t helped. Suggestions? Not really sure what would be appropriate considering this bolt goes into the frame and supports the subframe.
Old Jul 4, 2020 | 06:54 AM
You may end up having to cut of the bolt head, removing the subframe, then cut the bolt off flush with the chassis, then partially drill out the bolt, try and use a easy out/ stud remover, being careful not to damage the thread.
tharry8
Aug 7, 2011 05:25 PM
ErikRS
Jun 7, 2011 09:13 AM
reggie53
Apr 21, 2011 11:29 AM
fspell220
Mar 10, 2008 04:21 PM
Steve88XJ
Jun 12, 2007 02:41 PM
