FOB Syncing Issues MAZDA 3
Old Dec 23, 2022 | 11:48 PM
JBABZ's Avatar
Default FOB Syncing Issues MAZDA 3
Hey All
I have a Mazda 3 Hatch 2005, and recently changed batteries on my FOB. When i went to lock/unlock my car, the car wasnt locking/unlocking
The red light came up on my FOB to signify that the batteries were working. so i decided to look online to sync the FOB keys to the car again incase it resetted for some reason
Anyways i did the whole process of keys in the ignition, door open, turn on off 3 times ect. That all worked fine as the locks closed and opened to activate ON MODE to SYNC the FOB. Then i pressed the FOB button to sync the keys, and then the locks opened/closed to signifty the end of the SYNCING MODE.
Yet when i went to use the FOB button to lock/ unlock the car, it didnt work.
For some reason the FOB is not registering, any idea why?
Its a weird one because the keys work as the red light comes up, but the car isnt picking the FOB signal up
i can only think maybe theres an issue on the cars signal to register the keys. Does it have a FUSE that might be stuffed ect?
help much appreciate
John
Old Dec 24, 2022 | 09:20 AM
Old Dec 30, 2022 | 11:23 PM
JBABZ's Avatar
Still not working, i have followed the below steps
Step 1: Open driver side door and leave open.
Step 2: Lock and Unlock the drivers door using the power door lock switch on the door
Step 3: Insert key into the ignition.
Step 4: Turn Key to ON position and return to Lock (off) position. Do this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off) position.
Step 5: Close and open the drivers door 3 times. Leave door open after this step
Step 6: ECU should respond by locking and unlocking the doors once.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series (about 4) of door locks and unlocks. You're done!
Step 7 does not work for me. But step 9 does
Help would be appreciated.
Dave33
Jan 17, 2022 04:39 PM
NewMazda2owner
Aug 6, 2019 11:36 AM
Wisey
Jul 6, 2019 07:18 AM
StrongEagle
Mar 8, 2016 11:57 AM
A Man In Blue
Apr 29, 2012 09:53 PM
