wont idle
Old Feb 10, 2011 | 01:55 PM
kenzspen's Avatar
Default wont idle
Hello all Mazda techs, i have a 2003 Protege5, was towed over with an alternator flatlined, found both power wires at alt burnt in half. i repaired wires and installed new alt and battery, now car will not idle, we have checked iac, air intake leaks, to no avail. any help would be greatly appreciated. oh yea i can keep car running, it just wont idle on its own.
Old Feb 16, 2011 | 12:34 PM
djs2571's Avatar
did you find the burnt wires before it was towed? Or is it possible the tow guy tried to jumpstart it and hooked the wires up backwards?
If the alternator died in a bad way, it could have put out high voltage and fried some electronics before the car died. I'd guess the check engine light is on now... may have a code to check.
You could get a scanner tool and see what different sensor levels are when the key is on - could lead you to what module is bad.
fmmcmillan
Aug 6, 2007 01:21 PM
Nskylinerb25
Oct 21, 2006 12:18 AM
turtlepro1.5ltr
Jun 2, 2006 11:04 PM
atlthiker
Jun 2, 2006 10:01 AM
kosmos
Jul 26, 2005 01:10 AM
