Random misfire cylider 4
Old Mar 11, 2015 | 09:54 AM
vinper's Avatar
Default Random misfire cylider 4
I have a misfire number #4 . I had already changed both coil packs , my thinking is plug or plug wire. question can I use timming light to check ,if it lights firing if not .not firing? . I had problems with fuel injectors in past and changed 2 of the 4 cylinders injectors for flooding cylinders
Old Mar 11, 2015 | 10:17 AM
hixx's Avatar
Swap coils around and see if the code moves with it. A timing light will not work.
Old Mar 11, 2015 | 10:34 AM
vinper's Avatar
both coil packs are new. each pack feeds 2 cylinders. how can you test for fire without going to a scanner?
Old Mar 11, 2015 | 10:55 AM
hixx's Avatar
A test light. The coil has 12 volts with the key on. The PCM grounds it to fire so a test light connected to the positive side of your battery and probing the ground circuit of the coil will flash. Did you replace the plug wires? A bad injector is uncommon. A dirty injector with a bad spray pattern is common as dirt. A bottle of Techron in the gas tank will quickly cure the latter.
Old Mar 12, 2015 | 09:48 AM
vinper's Avatar
I have 2 spare injectors . what side is #4 cylinder?
Old Mar 12, 2015 | 11:56 AM
hixx's Avatar
Number one is the front of the engine. Number 4 is the back of the engine. 1-2-3-4
Old Mar 12, 2015 | 01:32 PM
vinper's Avatar
My engine is horizontal side to side mount
Old Mar 12, 2015 | 02:19 PM
hixx's Avatar
The front of the engine is where the belts are.
hilarie19
Feb 11, 2015 10:20 PM
paqman
Jul 6, 2013 09:49 PM
will4557
Jan 18, 2012 07:56 PM
SchecterGuy
May 30, 2010 04:26 AM
CardsFan420
Nov 8, 2006 06:25 PM
