1993 Mazda Protege AC problem
Old 06-05-2011, 08:14 PM
tdillin's Avatar
Default 1993 Mazda Protege AC problem
Hello all. I have a quick question about diagnosis an AC problem. Currently, the AC in my 1993 protege doesn't work. It worked fine until a small accident (I know this is going to be a pain to track this down). Now when I hit the AC switch, I hear the idle kick up and the radiator fan kicks on. The light does not come on neither does the condenser fan. I know the condenser fan works because I put power to it and it spun. The high side pressure showed something over 100 when I checked it last(i think it was like 130 but I don't remember, this was with the system off).
Is there any way to by-pass the system and force the compressor on? I assume I must have blow a sensor/relay/switch but have no idea what or where. I checked the fuses and relays in the box and they appear good, but I don't know where anything else is located. I've checked my repair manual but have not gleaned anything too useful. Is there anything else common I can check or how to proceed in trying to track the issue down. Thanks for the input.
Old 06-16-2011, 08:04 PM
tanprotege's Avatar
Was the compressor touched or hit during the accident?
I would look at the AC clutch assembly.
Old 06-28-2011, 06:28 AM
webf2011's Avatar
It seems like compressor has damaged during the accident. Why don't you get it checked once.
DAKristof
03-18-2015 01:10 PM
7046fred
03-11-2014 07:11 PM
djmarch
01-24-2012 05:29 PM
NvMySi
11-28-2007 08:07 PM
violenza
03-18-2006 04:05 PM
Quick Reply: 1993 Mazda Protege AC problem
