1993 mazda protege will not run in gear
Old Feb 27, 2014 | 07:10 PM
7046fred's Avatar
Question 1993 mazda protege will not run in gear
my 1993 start up find but in gear it shut down ,when the car get warm.
the only thing I did is put in spark plug and change the air filter then everthing went bad
Old Feb 27, 2014 | 07:22 PM
tanprotege's Avatar
Hi 7046fred: your description is too vague to tell the problem. Please read the sticky "the unofficial user's guide to the mazda protege." It does not matter which year protege. Check the things that are listed, vacuum leaks, MAF sensor etc. Let's see if you can find some things that are out of order.
Report the things you do and how the car responds.
Old Feb 28, 2014 | 09:13 AM
7046fred's Avatar
Default change
I change mass air flow senor same thing happen. NO Vaccum leak
it run while cold not
help
Old Feb 28, 2014 | 11:21 AM
tanprotege's Avatar
7046fred:
I really like to help you. But we need to be able to communicate. It does not matter if your English is not perfect, as long as I can figure out what you want to say.
From your first post I can tell that your engine runs when it is cold. It stops when it has warmed up.
Your second post tells me that you changed the MAF sensor. But I don't understand this sentence: "it run while cold not "
I like to know: how many miles or kilometers are on the car.
did you clean the throttle body?
Is the Check Engine Light on or blinking?
Old Feb 28, 2014 | 01:28 PM
Juanky's Avatar
do the engine run ok when cold? no misfires? for what i can tell, the car run ok while in open loop. but dies when it warms up. thats when the car goes into closed loop and some sensors are used to control the engine.
Old Mar 1, 2014 | 04:35 AM
Put your old spark plugs back, put your old air filter back in. Make sure everything is plugged in & connected. Double check there are no cracks in the large rubber hose going from your air filter box to the engine.
Old Mar 1, 2014 | 05:52 AM
7046fred's Avatar
Default 1993 mazda
ok the car run in gear cold. It has 1 92000 mile, no check engine light is on ,
no I did not clean the throttle body but its looks clean
I throw away the old spark and filer I also change the intake hose
Old Mar 1, 2014 | 07:57 AM
tanprotege's Avatar
As grim reaper said: make sure everything is plugged in. Look for every wire harness. Unplug, clean and reconnect it. Look for the connectors to the MAF sensor, HO2 Sensors, Air Temperature Sensor and ECT (Engine Coolant Temperature) Sensor.
Did you get a new MAF sensor? Did you throw the original MAF sensor away?
Old Mar 2, 2014 | 08:02 PM
Juanky's Avatar
check the egr valve too.
Old Mar 10, 2014 | 09:17 PM
7046fred's Avatar
Default anything else
I cleaned and checked every wire on the car and the same thing happen.
would a cross spark plug wire Cause this or a bad spark plug.
Any thinks?
