Cranks but won't start - 2003 Protege 4cyl
Old Sep 23, 2013 | 02:04 PM
eric1234's Avatar
Smile Cranks but won't start - 2003 Protege 4cyl
Had my radiator spring a leak while driving, and the leak was just below the fill cap, and water got on the engine.
Replaced the radiator, but now the car will not start. Cranks okay, but will not start.
This car does not have a schraeder valve on the fuel rail, so how do I check the fuel pressure ? Also, it seems to have spark, as when I put my timing light on the spark plug wires the timing light flashes.
Has anyone got some common sense on how I can troubleshoot this ?
HELP !!!1
Old Sep 23, 2013 | 09:22 PM
tanprotege's Avatar
Did the ignition parts get wet? Is there coolant down in he spark plug tubes? pull the coils an wires but leave the plugs in. Use rags and strong paper towels/ shop towels to dry the bottom of the plug tubes. Also dry the ignition parts you took off. Then put it back together and give it a try.
Gregm
Nov 25, 2022 04:46 PM
Protospeed
Feb 9, 2015 09:11 PM
Orange_Monster
Jun 1, 2011 05:44 PM
chadm_88
Aug 4, 2008 02:54 PM
ansonone
Mar 27, 2008 09:07 PM
