99' Protege Transmission O/D flashing and only 1st gear
Old Jan 22, 2013 | 06:37 PM
JustTheSix's Avatar
Default 99' Protege Transmission O/D flashing and only 1st gear
Hello all!
I have a 1999 Mazda Protégé that I recently bought used and as is. It is automatic with 148k miles. Recently, it has acquired a problem with shifting. When I start the vehicle up to drive it, it will drive and shift from 1st to 2nd gear, but once I come to my first stop and go to drive again it stays in 1st gear will not shift into the next gear. Within minutes after this happens, the O/D light flashes. It continues to flash whether you are moving or at a stop and in park. If you go to shift the vehicle into D or R while this O/D light is flashing it shifts hard and abrupt. If you turn the vehicle completely off and start it right back up the O/D light is off and when shifting from D to R is shifts smoothly, mind this is all while I am sitting still in my driveway. I did pull the pan off and drain the fluid in there, I know the torque converter still holds a few quarts so wasn't able to get to that. The fluid was very dark and old, but there were no metal shavings. I replaced the transmission filter and gasket and cleaned the pan out as it was nasty. I also replaced the vehicle speed sensor as I have heard those can cause issues if they are bad, but still no luck and no change in the driveability. The new transmission fluid does not smell burnt. It had a check engine light code at one point that said P0751 I believe. Anybody out there who has first hand experience with this problem or any recommendations would be greatly appreciated. I have a spare transmission laying around, but I prefer to not swap them out as I am holding on to that one for my lime green 00' Protégé. Thanks guys
Old Jan 23, 2013 | 01:22 PM
tanprotege's Avatar
Well, I don't have first hand experience.
That out of the way: you have a bad shift solenoid or a sticking valve. The code would point to the shift solenoid.
You need to fix this because the clunky shifts can do serious damage.
spiramirabilis
Nov 27, 2012 08:54 PM
germs666
Sep 28, 2010 01:38 PM
leftygolfguy
Nov 30, 2007 08:55 AM
raysoden
Mar 7, 2007 02:25 PM
stunad#1
Oct 2, 2006 06:23 PM
