struts - aftermarket or OEM
Old May 24, 2022 | 02:44 PM
Circeo's Avatar
Default struts - aftermarket or OEM
Hello friends,
I'm replacing the struts on a 2001 Mazda MPV. I've researched out parts and found some good KYB shock kits (struts, mounts, coils, etc) and also just the OEM struts are about the same price. I think KYB is a good brand, but I don't have enough experience with this car to make a decision. I'm a nissan/hyundai guy and on my cars I'd go with OEM every time, reusing most of the other parts.
I'm hoping one of you would have more experience with this, because I know there are a few parts on some cars that OEM is worse than aftermarket.
Old Jun 24, 2022 | 07:22 PM
FWMPV's Avatar
I put KYB struts on my 2002 MPV. I, and more importantly, my wife, are very happy with them.
I can't really compare with OEM as the struts were shot when I got the vehicle.
The only downside to the KYBs was that I couldn't find an assembly. I had to buy the bare struts and have my mechanic build them up using the OEM springs and such.
They are easy to install. You may want to put in a cam adjustment bolt while you are at it.
Good luck!
Old Nov 2, 2022 | 11:05 AM
Armor01's Avatar
Default Struts and Shocks Replacement
Just replaced the struts and shocks on my daughter's 02 MPV. I installed KYB at all 4 corners and I did not use an ALL IN ONE KIT. They are out there on Rock Auto and at Auto Zone. I didn't install the A.I.O.s because the new springs raise the height and Mazda wants a lot of $$$ for rear springs. At 101,000 miles, they were due for a change. Now on to the new tires and alignment.
Old Nov 2, 2022 | 11:15 AM
KYB for the WIN!!!!!!!!!
As a temporary upgrade to the rear shock/dampeners on my Mazda I instaled KYB Gas-adjust(none applicated) . What a great difference it made. The KYB EXCEL-G standard replacement for OEM< Mazda are a good upgrade as well!
Stock OEM dampeners/shocks rear:
KYB after painting them RED and adding a RED boot.
Larry Bushey
Apr 2, 2021 04:13 PM
SuperDad
Mar 11, 2019 03:56 PM
mazda626h
Feb 23, 2014 07:48 AM
ntstock93
Mar 4, 2011 09:23 AM
LS7 Thunder
Jun 19, 2007 05:40 PM
