mpv 2.0TD clutch replacement
can anyone help me with which way round the clutch drive plate is fitted to flywheel usually in most cases its the flat side that is against the flywheel but in this case it can go both ways it has a marking that says T/M side does anyone know what this stands for as any markings i've seen before usually say flywheel side. The clutch was stripped before I went on holiday and on my return had been movedso i'm none the wiser.
thanks
thanks
