Some times, Car does NOT starts/ engine ignition doesn't start.
Old Apr 28, 2024 | 04:32 AM
Mustafa's Avatar
Default Some times, Car does NOT starts/ engine ignition doesn't start.
Mazda CX9 2016, AWD, (280,000 Kms Run), Key less Start. (replaced the battery with new, last month. )
when the start key rotates, all the panel lights gets ON. But ignition could NOT start.
Then keep trying multiple time, and randomly starts at some trials. typically take 5-10 Minutes delay.
Issue happens occasionally ONLY.
when we put the gear in Neutral gear & press brake & start , engine gets started immediately.
Kindy advise the probable causes, and feasible remedy.
Old Apr 28, 2024 | 08:24 AM
Old Apr 28, 2024 | 08:27 AM
The first thing is to use a diagnostic scanner and check for any DTC's.
With the language challenge and it is likely I think you are using a translator it will be difficult to help you. At least for me!
(280,000 Kms Run), is a lot of miles so there simply could be several parts, sensors and other systems worn out.
I need more clarity on what you discibe as not starting?
misfitlife
May 7, 2021 02:54 PM
kizzoboy
Sep 25, 2016 01:52 AM
JEFFREY97
Oct 30, 2012 10:14 AM
djdiamond
Aug 18, 2011 07:21 PM
sacork28
Feb 11, 2011 01:53 PM
