Error code P0016
Old Jan 19, 2020 | 11:10 AM
Josie Tabarez's Avatar
Default Error code P0016
My 2007 CX7 has the check engine light on with a diagnostic error P0016, crank/camshaft position sensor error. Losing oil and smell it’s burning oil. Can’t find any oil leaks. Oil changes done every 4 months. Replaced Camshaft position error, still P0016. Is this car worth $$$ to address the timing chain? It’s at 190km.
Old Jan 20, 2020 | 03:07 AM
DTC P0016:00 CKP-CMP correlation
I don't have that code for a CX-7, but for other Mazda engines it relates to a correlation issue between the Camshaft Position sensor and the Crank Position Sensor.
This could be a faulty sensor( either cam or crank), wiring fault, faulty PCM/ECU, incorrect valve timing, or a stretched timing chain.
Old Jan 20, 2020 | 03:09 AM
Just had another read of the workshop manual, and found P0016 for the facelift 2009 CX-7, it's the same as what I've already added.
mazda685
Apr 21, 2023 08:26 AM
BillSchipper
Dec 30, 2019 04:25 AM
Danno94
Mar 26, 2019 06:56 AM
Jini Bitzer
Apr 24, 2018 11:04 AM
greenjosh
May 24, 2013 10:19 AM
