Hey all, I could really use some advice.
Old Mar 24, 2019 | 09:01 PM
Danno94's Avatar
Default Hey all, I could really use some advice.
2005 Mazda 6, 2.3L 4 cylinder
Engine light comes on periodically for past month always showing code P0340, I've had the camshaft position sensor replaced, light came on throwing same codes, upon further inspection found timing was off by 2 teeth. Took car to Mazda dealer had valve cover replaced, oil changed, had timing chain reset and had camshaft position sensor replaced for the second time.
Engine light came on again tonight throwing same code now a month and about $1200 later. Any ideas?
Old Mar 25, 2019 | 04:34 AM
There's was a bulletin (2004) out in my market for pre-facelift GG & GY Mazda 6's. It mentioned incorrect chain timing & also a Malfunction in the CKP ( Crank Position Sensor )
Old Mar 25, 2019 | 06:05 AM
Danno94's Avatar
Thanks for the reply @grim_reaper I have checked the VIN number on a few sites and have confirmed that there have been no recalls on this particular 2005 Mazda 6 4cyl 2.3L sedan. It has 94k miles. I was told by a Mazda dealership in New York that the only reason it would have jumped timing is because of low oil, or no oil, which was allegedly the result of my warped valve cover that had been hemorrhaging oil. This was also thought to be the reason why the Crankshaft position sensor had been damaged or ruined. Anyway the Mazda dealer assured me that the timing chain and relevant mechanisms were all good and that they just simply needed to be reset.? So we reset the timing chain to factory specification and replaced the valve cover and put a new crankshaft sensor in for the second time this month. I am going to call Mazda again when they open this morning and take it up with them - if the chain was shot wouldn’t they have told me, instead of wasting time and money resetting it? I’d have to insist if that were the case that the money I gave them to reset it would have to go towards the following procedure to replace it altogether.
Old Mar 25, 2019 | 03:36 PM
It wasn't a recall, jusy a tech bulletin in my market, note: I'm not in the USA or Canada
You can confirm both the cam & crank sensors were replaced?
Old Mar 25, 2019 | 10:34 PM
Danno94's Avatar
Ah I see, so i was able to get in touch with my tech today, he confirmed that the timing chain was perfectly fine, which is why he opted to reset it rather than replace it. Also while the camshaft position sensor was replaced and is brand new, the crankshaft position sensor has never been replaced and is the original one that came with the car. I think it might be more cost effective to replace that crankshaft sensor around $350 USD. Otherwise I'll be paying hourly for mazda to look through the wiring of the engine harness scouring for open, or shorted circuits. By the way its worth mentioning, the ECM (computer) the battery and the alternator have all been replaced within the past year.
Also im at 94k miles, transmission fluid is (allegedly) burnt, and has never been replaced. I have called and asked a handful of mechanics and Mazda dealers in the New York and tri-state area and I have heard mixed reviews, more than half of them say don't bother changing the transmission (transaxle) fluid as its already too late they say if i change it ill end up needing a new transmission very soon, as its already too far-gone, they insist that I just ride it out and I could end up getting considerable more time out of it before it goes. While a handful of mechanics told me that I should change it, saying I may have a chance especially if I use some of the Lucas transmission additive which is supposedly very good for older transmission and may do the trick.
Either way i feel like im on thin ice with this piece of **** car, i've never owned a car that was like this before in my life.
Old Mar 26, 2019 | 06:56 AM
For peace of mind and longevity, the trans fluid should be changed every 40 to 50,000 miles.
Yes if its flushed now, you could stir up crap & kill the trans now, on the other hand, flushing it may save it & prolong its life.
Hillbillymarine81
Jun 24, 2006 03:49 AM
Mechman12867
Jul 9, 2005 11:06 PM
