Trans Fluid Check @ 122 F
Old Sep 30, 2023 | 05:27 PM
george m44's Avatar
Question Trans Fluid Check @ 122 F
If transmission fluid level was checked at max operating temp. as opposed to 122 deg.F marked on dipstick, would there be any significant change in fluid level ? Is the 122 F just the minimum temp required for checking level or must it be at that exact temp ?
Is there any way to check the fluid temp without a some kind of electronic scan device?
Thank you.
Old Sep 30, 2023 | 11:42 PM
Thermostat for coolant opens at 129f that is also when the coolant light turns off from cold start. At that time 130F+ coolant is warming the transmission fluid along with the engine itself. It takes on a 60F day about 3-5 minutes of a short drive to bring the transmission to full operating temperature which will be at least the same as to coolant at this point 150F+ and you can check the ATF fluid level.
You will also at this point of temperatures be in closed loop ECU engine operations.
Simple...
ASE
davidhirst001
Feb 6, 2023 04:59 AM
Stephann
Jun 9, 2021 09:37 PM
Mbciuso
Apr 12, 2016 03:36 AM
mzd507et
May 17, 2011 09:50 PM
bobbyt46
Jul 7, 2007 08:58 AM
