How hard to do coolant service?
Old Jan 2, 2023 | 05:22 PM
Grouch's Avatar
Originally Posted by agaurav
I bought 2 gallons of the original Mazda FL-22 coolant. Watched a couple of YouTube videos but not 100% clear and hence these questions:
1. Do I need to measure how much I drained to be able to put the same amount + some more? Can I not tell how much I need by just looking at the reservoir level?
2. Do I need to burb the system for removing air bubbles?
3. Do I need to run distilled water through the radiator at least once? How bad is it if I just drain all existing coolant and then just add new coolant?
Thanks.
If you used a premixed coolant from a major producer, like Peak, Preston et al, they use distilled water to mix it. The coolant you drained was still good as far as the anti-freeze properties were concerned. It's the anti-corrosion you are renewing. The dissimilar metals like to create electrolytic corrosion. As for burping it, if you opened the heat control, let it run until you get heat and the thermostat opens. The Mazda system will burp itself. Once the thermostat opens, fill the reservoir to the hot mark and shut the car off. Close the cap and you're done.
Be glad you don't have a BMW. The last one I worked on was a real bear to get the air out of. I got it done, and the owner was happy as the last guy to work on it almost ruined the engine.
Old Jan 3, 2023 | 08:55 AM
Thanks.
If you are flushing the system then you need to run clean water through the system until it runs clear.
Antifreeze properties degrade over time so replacing and flushing the system is the only correct way to insure a cose to completely replacing the coolant.
"BURPING" coolant seems to be a confusion with not only DIY but mechanic's.... The easiest way to ensure that your cooling system is to refill with the radiator cap at at least 2-4 degree upward incline. There is ALWAY air in ALL cooling systems another funny misconception ... remember coolant has 2 main ingredients one is water or H2O. H2O means that each watermoleculecontains one oxygen and two hydrogenatoms.
There are some engine that the head designs were not the best and had a tendency to have air pockets that when the oxygen was not removed could super heat the moisture creating hot spots and fluctuation in the coolant temperatures. These were for the most part rare and most auto manufactured either changed their head design for the production of the engine or gave more details on how to fill the cooling system. As far as I am aware of no MAZDA from manufacture 1990 and ner ever had a head problem effecting the cooling system?
Seems you indicated the use of MAZDA coolant you do not technically need to add any water.
When in doubt or question any service method it is always best to use the FACTORY SERVIVE MANUAL or if available Haynes, Chilton, Clymer service manuals and NOT general internet information that are often filled with flaws!
Steve Parker
Apr 22, 2021 09:13 AM
rtaylor
Mar 22, 2021 08:44 AM
rlb
Jun 24, 2014 02:16 PM
Ktulu
May 1, 2009 03:35 AM
ignis
Oct 27, 2007 11:25 PM
