How hard to do coolant service?
I went to get an oil change for my 2014 CX-5 Touring 2WD with 105K miles at Wheel Works today. The service person said that the coolant level is low. He recommended that anyways the car is 10 years old (bought in Feb 2013) and with 100K miles, I should do a full coolant service.
Question - can I just drain the current coolant and fill new without a full flush? If so, can I do this myself (I would like to learn - have changed battery, cabin and air filter before)? I assume that I remove the plug at the bottom, collect old coolant in a pan and then close the plug and put new coolant in radiator?
Separate related question - if I do go to a tech (third-party or authorized Mazda dealer) then how much should I expect to pay in San Franciso Bay Area, California? thanks.
I don't think I have it in me to flush. That seems too much work to run distilled water and burp the system and so forth. Or can I somehow find FL22 and then not flush?
Thanks for your help. I was thinking that I will not change the coolant and use the exact same FL22. But it seems that there isn't much available now?
But if you are still concerned you only need to elevate the front about 3 degrees' during the filling of coolant. Flushing the old coolant is not that difficult and actually as easy as flushing an American made car from the 60-70's.
It's fairly easy to do. Just be sure to get Mazda specific coolant. For some reason instead of just the good old fashioned green coolant, there are different colors and different specifications. I don't remember the color Mazda uses but there are two types. One for Mazdas and one not. It will say on the jug if it's for Mazda.
I would suggest that we all no longer judge what coolant to use in any cooing system anymore based on the "OLD SCHOOL" methods of color.
Speaking of color this also goes with other fluids like automatic transmission fluids as well.
ha! mine now in the Mazda is completely red but in Camaro's racing automatic it is almost clear and in one of my TH400 it is Blue.
I bought 2 gallons of the original Mazda FL-22 coolant. Watched a couple of YouTube videos but not 100% clear and hence these questions:
1. Do I need to measure how much I drained to be able to put the same amount + some more? Can I not tell how much I need by just looking at the reservoir level?
2. Do I need to burb the system for removing air bubbles?
3. Do I need to run distilled water through the radiator at least once? How bad is it if I just drain all existing coolant and then just add new coolant?
Thanks.
Thanks.
