FL22 coolant
Old Jun 22, 2014 | 12:51 PM
rlb's Avatar
rlb
Default FL22 coolant
My 2011 CX-9 needs some anti-freeze in the reservoir. It says to use FL22 coolant. Is this a Mazda specific coolant? I have seen in other threads that some people have used other long life coolants. Are there any other coolants that are safe to use with the CX-9? The Mazda FL22 seems kind of expensive.
Old Jun 23, 2014 | 07:10 AM
The FL22 coolant is a long-life coolant, 10yrs / 250,000kms.
If it only needs a small amount you can add de-mineralised water, which will slowly mix with the rest of the FL22 as it flows in & out of the resivour. What size bottles do they sell FL22 in where you are?
Old Jun 23, 2014 | 09:49 AM
rlb's Avatar
rlb
It was $31 for 1 gallon at Amazon. It is at the low line in the reservoir. How much is it usually at Mazda dealers? Any other cheaper alternatives?
Old Jun 24, 2014 | 06:34 AM
When the engine is cold, the coolant level should be at the low mark. When are you checking it?
Old Jun 24, 2014 | 02:16 PM
rlb's Avatar
rlb
It is just below the low mark when engine is cold. I will check again with hot engine.
ozmazda1993
Jul 15, 2024 12:27 PM
kunkunu
Apr 7, 2017 11:49 AM
Jmarcin
Jul 9, 2014 07:09 AM
Stevoh
Jun 21, 2010 03:17 AM
