2021 CX-5 Oil Cooler/ ATF Cooler?
Old Jan 2, 2022 | 08:04 AM
reubenvabner's Avatar
Thank you Conrad 16.5. Appreciate your feed back. Reuben
Old Jan 2, 2022 | 08:27 AM
Conrad 16.5's Avatar
See this thread for more info on a transfluid cooler for the CX.
2019 CX-5 Diesel Aftermarket Transmission Cooler | Mazdas247
Post #3 is particularly informative.
Old Jan 2, 2022 | 08:35 AM
Thank you Conrad. I will definitely have a look. Best, Reuben
Old Jan 2, 2022 | 10:13 AM
Originally Posted by Conrad 16.5
The above bolded section is incorrect. Transmission fluid is NOT pumped through this system, it's coolant from the radiator that gets pumped through. If it was trans fluid adding a trans cooler would be MUCH easier.
Adding a transmission cooler to MAZDA Skyactiv 2.5 is very, very and very easier than the old cooler in radiator or at least simpler in the installation.
Mazda Forum - Mazda Enthusiast Forums - Reply to Topic
Here are the basic parts I have machined or acquired for the project. I may still make some more changes as I get closer to the actual installation. I have not yet finalized exactly how I will be controlling the fan yet either nor have I started the relay and switch harness for it. I did swap out the original intended cooler for this one in the picture. The Transmission inline filter adapter can be used with many brands and type of spin on filters.
All parts are only lightly placed for the pictures. There respective type and location may change during the installation. The hose in the picture is not high Pressure hose and will be
changed out for High Pressure hose for the installation
Old Jan 2, 2022 | 10:52 AM
Very interesting! The grey machined part with three bolt holes takes the ATF fluid as it leaves the transmission headed for the cooler? And then returns it to the body of the tranny?
Old Jan 2, 2022 | 11:36 AM
Yes, that is one I made. Basically, copied the outline of a Transmission Service Adapter and machine my own using mush larger AN fittings and NO O-rings. The service adapter used O-rings and the fitting were to small IMHO to carry a large volume of fluid quickly in and out. (See AN flow chart). You can get the adapter and use it as it is and then easily install a transmission cooler. I choose cooler with fans and also an added adapter for a spin on oil filter for easier and more frequent transmission service. The fan/cooler option allows for many more spaces to mount a cooler because it does not need direct air flow to be effective. The installation even for a DIY and simple garage tools for everything is about 3 hours? This will at least keep your transmission temperature well withing the safe limits between normal operation of 180F-210F and towing between 220F- 245F.
You should not need a thermostat valve but at any time could easily install one. You don't live in Alaska so I wouldn't worry?
For my MAZDA at some point I will also be installing a large capacity oil pan.
Old Jan 3, 2022 | 07:33 AM
What the hell? How is this easy? You had to machine a part to make this happen right? Do you think that just anyone on the street has the ability to machine a part for their car?
Need a part machined? I'll just run down to my basement shop and fire up the ole CNC and get that made right away.
Old Jan 3, 2022 | 09:45 AM
What the hell did you not read what I said? LOL Go -re-read Conrad!!!!
**Adapter that will work for about 30 bucks. I said I did not like that it had o-rings so I made my own!!!!
Funny but don't you actually read some of the information that you post to help members? Go back and look at the information you posted about transmission Coolers.
**adapter
LOL
Old Jan 4, 2022 | 07:49 AM
**adapter
LOL
Here is what you said and what I replied to.
Old Jan 4, 2022 | 09:51 AM
Right so as I said you did not read your own posted information LOL
If you had not responded I doubt anyone would have even cared really what you said or my response now you have posted again, and again you are getting the information inaccurate! Thier is a difference between when I said what someone could do and accomplish on a project and what I do!
I would guess for a DIY the installation of a simple aftermarket universal cooler kit , 3-4 hours with what most have for tools in their garages?
Sojourner55
Dec 8, 2021 06:44 PM
firefox111
Mar 16, 2020 12:15 PM
kaimanson
Feb 20, 2019 02:54 AM
awconverse
Sep 22, 2015 03:10 AM
JKoolMann
Sep 17, 2005 04:44 AM
