OEM Oil filters model for CX-5
Old Feb 13, 2019 | 07:41 PM
kaimanson's Avatar
Default OEM Oil filters model for CX-5
After doing a online research about which mazda oil filter is the best for a CX-5, i'll like to hear from you guys.
1. 1WPE-14-302
2. PE01-14-302A-MV
Old Feb 16, 2019 | 08:07 AM
Arkainzeye's Avatar
What engine do you have ? I saw a bulletin for the Mazda 2.5 L, where it said specifically use a Mazda oil filter.. I'm NOT suggesting you can't use another brand, I'm just saying if you wanted to use a Mazda oil filter, the bulletin was saying do not use just any Mazda oil filter use one specifically for the 2.5
Old Feb 16, 2019 | 08:13 AM
shipo's Avatar
This falls under the heading of "Over Thinking" things. Regardless of whether you use a Mazda oil filter, a Fram, Wix, Napa, Pure, STP, Champion, K&N, or Mobil1, the longevity of your engine will not change.
Old Feb 16, 2019 | 08:23 AM
Arkainzeye's Avatar
Well said !
Old Feb 16, 2019 | 09:22 AM
3carmonte's Avatar
If the worst filter (Fram) is the same at preventing engine wear as the best filters (K&N and Mobil-1) then why not just bypass oil filtration all-together since by the logic presented it does nothing to extend engine life anyway! This fly's in the face of automotive engineering and common sense.
Old Feb 16, 2019 | 10:16 AM
Arkainzeye's Avatar
But that isn't actually what was said ..
Old Feb 16, 2019 | 10:17 AM
kaimanson's Avatar
2013 - 2.0 engine
Old Feb 16, 2019 | 10:28 AM
shipo's Avatar
Sorry, but it appears you buy more into urban legend than science. Show me a single scientifically competent study which shows engine wear is increased when using a Fram filter versus a Mobil 1. Here's a hint; you will not be able to find one.
Old Feb 16, 2019 | 01:33 PM
3carmonte's Avatar
Lightbulb
From 1988. https://www.upmpg.com/tech_articles/...udy/index.html
Old Feb 16, 2019 | 02:12 PM
shipo's Avatar
Sorry, your link is a fail from so many perspectives I wouldn't know where to start. Simply put, it in no way suggests a Fram (or other low end automotive filter) will reduce engine life in any way shape or form.
