a/c system
Old Jun 5, 2015 | 08:37 AM
dragonmp5's Avatar
Default a/c system
I have a 93 b2600i and I'm looking to get the a/c switched over to r134. Has anyone changed theirs over or know where I can get a kit without costing too much?
Old Jun 7, 2015 | 09:11 AM
Cusser's Avatar
People I know have converted their Mazda trucks systems successfully to R134a. Note that the R-12 type "mineral" oil must be removed, not so easy.
I suspect that you have/had a leak of refrigerant, why you are considering changing. I'm in Arizona, installed a new compressor myself in my 1988 B2200 last October, stayed R-12. The higher cost of R-12 is offset by the simplicity of not changing over. If you haven't fixed your leak, then you're throwing your money away either way, as refrigerant is not a consumed item (I've got a '98 Frontier with 201K that's still on its original refrigerant).
Old Jun 8, 2015 | 03:21 AM
dragonmp5's Avatar
I've talked with a guy i work with and he has all the equipment needed to evacuate, flush and test before adding r134. I should be able to save over $100 from having a shop do it, besides i don't know where to get r12 nor do i have the permit to get it.
Old Jun 8, 2015 | 08:08 AM
Cusser's Avatar
One can buy R-12 on Ebay. Some vendors will require the certificate, about $25 online.
Just don't add anything with sealers or leak stop, you'll ruin the system. A little UV-dye is OK. That guy sounds like he knows what he's doing if he can flush the system. He may not do R-12 because he has little call for it so doesn't have the legally-required separate recovery/fill equipment.
Shawn Element
Apr 16, 2014 01:08 PM
TheRedBaron
Oct 30, 2005 01:13 PM
wjrusco
Jun 15, 2005 05:52 PM
bkeogan
May 21, 2005 02:26 AM
