Hood release cable broke off 90 323
Old Dec 13, 2008 | 10:08 AM
v_balge's Avatar
Default Hood release cable broke off 90 323
When I tried to open the hood the release cable broke off. Now I can't open the hood.
Any suggestions on how to release the hood latch from outside car.
Thanks in advance.
Vince
Old Dec 13, 2008 | 05:12 PM
kalesh's Avatar
Default RE: Hood release cable broke off 90 323
It is possible but difficult.
First check if there is a guard under the front bumper, if so remove it. then reach in from the place between the bumper and radiator up to the hood latch and see if you can feel where the cable is attached to the hood latch.. if you can then push/pull on it and it should release. If you cant feel it then you may need to remove the bolts mounting the latch to the body (usually 3 or 4 10 mm bolts) then the latch should move enough to give access.
twistertime
Jun 19, 2012 07:03 PM
sylar
Jan 13, 2012 05:48 PM
Marjnal
Jun 1, 2011 06:36 PM
Manhattan
Mar 28, 2011 05:13 PM
elj61354
Jan 30, 2008 09:37 PM
