88' 929 not starting...dont know where to start
Old Mar 21, 2019 | 02:47 PM
Josoboring's Avatar
Default 88' 929 not starting...dont know where to start
I have a 88 Mazda 929 with a 3.0 v6 automatic trans in it. Only 123000 miles and runs perfect. Well ran perfect... the other day I was driving when the motor just died. Battery still on, all interior lighting, radio, sub and amp all working. I pulled over and tried to start but the motor only turns over. I've checked battery and fuses and all look fine. After testing the fuel pump I realized it had stopped running. I checked the harness and fuse points for any voltage drops and none were found. But the pump loses all power past the connector to the pump itself. I'm at a loss at the moment and don't know where to start next. Anyone have any ideas? This is my daily car so im trying to repair asap.
also I have since replaced fuel pump but still no power.
Old Mar 22, 2019 | 06:48 AM
What happens if you supply a external power supply & earth to the new fuel pump?
Old Mar 23, 2019 | 02:11 AM
Josoboring's Avatar
I tried that and the pump ran fine. Once I out it back in the tank it dosent run though.
Old Mar 24, 2019 | 12:43 AM
If it runs outside the tank, why won't it run in the tank? Are you still using an external power supply & earth?
FrankRamizi
May 18, 2011 10:18 AM
madformazda
Aug 29, 2009 03:06 PM
MtechTellsTruth
Mar 4, 2008 10:31 PM
jessica_leaann
20
Mar 21, 2006 04:26 AM
TipTron3
Jul 23, 2005 03:25 AM
