machining 101. all FAQ about machining answered here.
all referenced for your convenience. thanks BogusSVO.
https://www.mazdaforum.com/forum/general-tech-6/how-aluminum-head-pressure-tested-cracks-21533/
https://www.mazdaforum.com/forum/general-tech-6/how-lap-valve-21534/
https://www.mazdaforum.com/forum/general-tech-6/how-check-head-warp-21536/
https://www.mazdaforum.com/forum/general-tech-6/back-cutting-valves-improved-air-flow-21532/
https://www.mazdaforum.com/forum/general-tech-6/why-not-let-your-head-belt-surfaced-21535/
https://www.mazdaforum.com/forum/general-tech-6/how-change-valve-guides-alum-head-21540/
https://www.mazdaforum.com/forum/general-tech-6/how-replace-seat-head-21541/
https://www.mazdaforum.com/forum/general-tech-6/how-test-valve-springs-21545/
https://www.mazdaforum.com/forum/general-tech-6/how-surface-flywheel-21546/
How an Aluminum Head is pressure tested for cracks
https://www.mazdaforum.com/forum/showthread.php?t=21533
How to lap a valve
https://www.mazdaforum.com/forum/showthread.php?t=21534
How to check a head for warp
https://www.mazdaforum.com/forum/showthread.php?t=21536
Back cutting valves for improved air flow
https://www.mazdaforum.com/forum/showthread.php?t=21532
How to check piston to deck clearance
https://www.mazdaforum.com/forum/sho...280#post103280
Why NOT to let your head be Belt Surfaced
https://www.mazdaforum.com/forum/showthread.php?t=21535
How to change Valve guides In an Alum. head
https://www.mazdaforum.com/forum/showthread.php?t=21540
How to Replace a seat in a Head
https://www.mazdaforum.com/forum/showthread.php?t=21541
How to Test Valve springs
https://www.mazdaforum.com/forum/showthread.php?t=21545
How to surface a flywheel
https://www.mazdaforum.com/forum/showthread.php?t=21546
How to lighten a stock cast iron Flywheel
https://www.mazdaforum.com/forum/general-tech-6/how-lighten-stock-cast-iron-flywheel-21555/
Engine machine work explained
https://www.mazdaforum.com/forum/general-tech-6/engine-machine-work-explained-21569/
How to R&R and Blaance Press fit pistons
https://www.mazdaforum.com/forum/sho...278#post103278
How to CC a Combustion Chamber
https://www.mazdaforum.com/forum/sho...279#post103279
How to install a Heil-Coil
https://www.mazdaforum.com/forum/sho...281#post103281
how to Fix, Balance and Hang full floating pistons
https://www.mazdaforum.com/forum/sho...284#post103284
How a block style cylinder head is measured for thickness
https://www.mazdaforum.com/forum/gen...57/#post135191
How to Measure, Mic a piston
https://www.mazdaforum.com/forum/gen...73/#post135261
How to surface an Aluminum Head for a MLS head gasket
https://www.mazdaforum.com/forum/gen...81/#post135315
What happens to a head in a machine shop
https://www.mazdaforum.com/forum/gen...ne-shop-30988/
Dropped Valve Head repair
https://www.mazdaforum.com/forum/gen...11/#post135425
Mazda BP Head tear down and tech
https://www.mazdaforum.com/forum/maz...29/#post135507
How to lap a valve
