Hey Great!! Thanks!!
Good idea. Wish I had thought of it. But may I suggest that you edit the post and title them, Wes? |
ok.. Ill get that worked on...
I just dropped another good one for you |
How an Aluminum Head is pressure tested for cracks
https://www.mazdaforum.com/forum/showthread.php?t=21533 How to lap a valve https://www.mazdaforum.com/forum/showthread.php?t=21534 How to check a head for warp https://www.mazdaforum.com/forum/showthread.php?t=21536 Back cutting valves for improved air flow https://www.mazdaforum.com/forum/showthread.php?t=21532 How to check piston to deck clearance https://www.mazdaforum.com/forum/sho...280#post103280 Why NOT to let your head be Belt Surfaced https://www.mazdaforum.com/forum/showthread.php?t=21535 How to change Valve guides In an Alum. head https://www.mazdaforum.com/forum/showthread.php?t=21540 How to Replace a seat in a Head https://www.mazdaforum.com/forum/showthread.php?t=21541 How to Test Valve springs https://www.mazdaforum.com/forum/showthread.php?t=21545 How to surface a flywheel https://www.mazdaforum.com/forum/showthread.php?t=21546 How to lighten a stock cast iron Flywheel https://www.mazdaforum.com/forum/general-tech-6/how-lighten-stock-cast-iron-flywheel-21555/ Engine machine work explained https://www.mazdaforum.com/forum/general-tech-6/engine-machine-work-explained-21569/ How to R&R and Blaance Press fit pistons https://www.mazdaforum.com/forum/sho...278#post103278 How to CC a Combustion Chamber https://www.mazdaforum.com/forum/sho...279#post103279 How to install a Heil-Coil https://www.mazdaforum.com/forum/sho...281#post103281 how to Fix, Balance and Hang full floating pistons https://www.mazdaforum.com/forum/sho...284#post103284 How a block style cylinder head is measured for thickness https://www.mazdaforum.com/forum/gen...57/#post135191 How to Measure, Mic a piston https://www.mazdaforum.com/forum/gen...73/#post135261 How to surface an Aluminum Head for a MLS head gasket https://www.mazdaforum.com/forum/gen...81/#post135315 What happens to a head in a machine shop https://www.mazdaforum.com/forum/gen...ne-shop-30988/ Dropped Valve Head repair https://www.mazdaforum.com/forum/gen...11/#post135425 Mazda BP Head tear down and tech https://www.mazdaforum.com/forum/maz...29/#post135507 |
