1996 MazdaProtege: Please Help Me Identify this Part (see picture)
Old Jul 7, 2013 | 09:57 AM
PundaSmith's Avatar
Default 1996 MazdaProtege: Please Help Me Identify this Part (see picture)
Hello,
My 96 Protege's AC is not working. The suspicion is that the refrigerant is leaking, and my mechanic suspects that the source of the leak from the location indicated in the picture attached.
We have two questions.
1. What is the name of the part (indicated by the arrow)? We suspect it is upper portion of the "Receiver/Drier". Is this the case?
2. Where does the wire (indicated by the circle) connect to? We suspect it connected to some kind of switch, but where?
I will appreciate any tips in this regard....
Thanks PS
Attached Thumbnails 1996 MazdaProtege: Please Help Me Identify this Part (see picture)-protege3.jpg
Old Jul 7, 2013 | 01:32 PM
tanprotege's Avatar
yes, this is the receiver/dryer. There should be a small harness with a blue and a green wire. In our '98 these wires are taped to the headlight harness. I assume that they monitor pressure or temperature to cycle the A/C on and off.
Old Jul 7, 2013 | 03:47 PM
PundaSmith's Avatar
Thanks very much. I see the Rockauto carries some parts, and I can get the receiver/dryer + pressure switch from them. However, I need the connector (the part that connects the wires).
Any reliable place to get aftermarket Mazda parts ?
cheers, PS
Old Jul 7, 2013 | 08:38 PM
GhostTribute's Avatar
I know for most other makes that I have worked on it is very hard to find those connectors individually. A junk yard would probably be an easier place to find that connector. Find the connector and cut it with a couple inches of wire still attached. Then you will have to splice your existing wires to the JY connector wires.
Old Jul 9, 2013 | 01:04 PM
vinper's Avatar
auto parts stores have some standard connectors electrical help section
Clutter66
Jul 20, 2013 07:52 AM
ottoman1384
Jul 18, 2012 07:05 PM
cturner183
Jul 10, 2010 03:34 AM
Sezza
Feb 8, 2010 08:49 AM
