Tranny fluid and filter for wife's 5?
Old 08-09-2012, 01:36 PM
orangeRcode's Avatar
Default Tranny fluid and filter for wife's 5?
The wife just got back from getting an oil free change and said the techs wanted to do a $250 tranny fluid change. I assume it's not rocket science but wanted a recommendation on the fluid and if there is any kind of filter.
Thanks for the input!
Old 08-09-2012, 01:40 PM
It's a 2009 btw.
Old 08-10-2012, 03:05 PM
Hello???
Old 08-10-2012, 04:12 PM
Kevinkpk's Avatar
My automatic tranny experieance is limited to changing filter (screen), and fluid on GM and Ford. My guess is $250 is way high, I'd shop around. You can do it yourself, I have a mazda haynes manual. If something isn't what I am posting, I'll look it up, and re post.
Remove the pan, if it has a drain plug, drain it first, if not put a collection pan under it. Remove all but the back row screws, then with pan under it, loosen the remaining screws till the pan tilts, and drains. Remove it, you should see a "screen" that is removed by a couple screws, thats the filter. Replace it, note there may be an O ring or seal you need to replace also, importan, if that is so replace it/them. I'd there also may be a magnet, I'll look and see in my Haynes where it is supposed to be located. Reinstall pan with new gasket, yea you will need to clean the old one off, then reinstall fluid. I don't know if yours has synthetic or not. I'd not mix it.
Old 08-10-2012, 04:31 PM
tanprotege's Avatar
Orange: did you look at the owner's manual?
BTW I get a tranny service for about $70 in my neck of the woods.
edgarcia57
05-26-2008 04:16 PM
maestro
04-09-2007 12:06 AM
PlatniumBlond
08-21-2006 04:37 PM
RX3WAGON
05-09-2006 06:47 PM
kpatz
03-15-2006 05:47 PM
Quick Reply: Tranny fluid and filter for wife's 5?
