Sponsored by:
Sponsored by:
Wrong fuel indication
Old 02-17-2017, 05:35 AM
yaelgor's Avatar
Exclamation Wrong fuel indication
Hi everyone,
I have CX5 2012 and a couple of months ago, a day after a periodic maintenance, my car stopped on the highway in the middle of a drive! Nothing worked. No gas was streaming in the pump. With the anratia power I barely pulled to the side of the road and the police rescued me by pulling the car to a safer place. I was unable to start the car.
Scary. The fuel gauge showed 1/4 tank.
Taken to the garage, the car did manage to start now, they replaced the gas flow meter, but apparently after two weeks it happened again to my spouse.
Needless to say this is awfully dangerous, the situation i went into on the highway was risky as hell.
Since then it happened once more (total of 3 times) and still the garage can't find the reason.
It seems to happen when the fuel gauge shows about 1/4 tank, yet the issue is not the fuel pump (which they claim is fine), nor is it the flow gauge which was already replaced in vain.
Any ideas?
Many thanks
Old 02-17-2017, 06:28 AM
2WD or AWD?
Old 02-17-2017, 06:41 AM
yaelgor's Avatar
2WD or AWD?
AWD. Cheers
Old 02-17-2017, 07:40 AM
paris1's Avatar
Sounds like it's going into "limp home mode". This happens when the ECU reads a serious fault code like an engine misfire. The dealer should be able to read this on his diagnostic equipment and get to the source of the problem. Are you using a Mazda dealer or an independent garage?
Old 02-17-2017, 07:56 AM
yaelgor's Avatar
Thank you. Using a Mazda authorized dealer. They have no clue thus far, what's the issue.
Old 02-18-2017, 10:16 PM
I believe the fuel tank in the 4WD version has two fuel level sensors in the tank due to the hump in the tank from the driveshaft running thru.
I've had a few RX-8's with the twin sensor setup having 1 sensor play up causing a false reading on the fuel gauge.
This causes the vehicle to run out of fuel with 1/4 of a tank showing on the gauge.
Something to get checked.
Old 09-22-2017, 10:48 AM
popielasty's Avatar
Hi,
did you fix your problem? I have same issue... My car is CX-5, 2.2 Skyactiv-D, AWD - 2014.
My fuel indicator was showing about 1/4 of tank and car stopped. I refill fuel - I was able to put only 40 liters of fuel and tank was full. In my opinion fuel indicator is fine, but there is another problem.
I know, that our fuel tank has like two compartments. Something is responsible to drain fuel from one compartment to the another, and I don't know what it is. I found some service manuals showing fuel tank in CX-5:
https://euroesi.mazda.co.jp/esicont/...4z7801600.html
There are some 'Fuel gauge sender units - main and sub' in fuel tank:
https://euroesi.mazda.co.jp/esicont/...200012002.html
But I can't see pump or something that can fill fuel from one compartment to another - can some one help?
lippert02
02-17-2012 12:30 PM
Thor_k06
07-16-2006 02:06 AM
bigzoom
05-22-2006 01:06 PM
Alucard
04-12-2006 03:20 AM
tul813
02-03-2006 06:44 AM
Quick Reply: Wrong fuel indication
