dealer cant find nothing wrong! HELP!
Old May 18, 2006 | 04:30 PM
bigzoom's Avatar
Default dealer cant find nothing wrong! HELP!
Took our 2001 prot 2.0L to the dealer for the low/ruff idle and high RPM at 70 mph and they put it on the machine and reset everything. still doing the same thing. i had them clean the air idle control valve, do whats called a PG cleaning which is suppose to clean the carbin out of the manifold. 300.00 dollars later... i changed the plugs, replaced the TP sensor before i took it in. does anybody have any other clues????? How would i check the injectors without the machine?? it seems to be using alot of gas...........Please help!!! girlfriend is driving me crazy about it not running right. thanks
Old May 19, 2006 | 09:45 PM
babyhuey's Avatar
Default RE: dealer cant find nothing wrong! HELP!
Did the dealer not have any idea why it had a low/rough idle? Base idle speed is adjustable so was that checked? Mass air flow sensors have been source of a lot of problems with idle and driveability problems on Protege for years. Higher rpm at 70 sounds more like a slipping trans though. Is this high rpm perhaps due to torque converter not locking up?
Old May 22, 2006 | 01:06 PM
bigzoom's Avatar
The shop manager said when he rode with us that he did not see anything wrong. we know the car and it is not right. I checked the mass air flow sensor like you said in some of your other replys and it was clean. didnt touch it. the only thing i did notice about it is that it sits at an angle in the air stream at a slight angle. is this normal?
MazdaTirol
Aug 26, 2012 05:03 PM
Baxter
Mar 25, 2011 09:45 PM
CombatMedic
Aug 8, 2009 09:09 AM
blazter1
Feb 3, 2008 08:05 AM
protegemaddness
Sep 21, 2006 08:28 PM
