Steering Wheel Swap - HELP!
So close but yet so far...
I've been trying to swap and enable cruise control on my '13 Sport Mazda2 and everything has been going well until now. Long story, but, I have been able to edit my ASBuilt and PCM files with proper checksum/hex-values to enable cruise via FORScan. Everything has worked flawlessly thus far.. Well I found a wheel with audio and cruise switches on EBay that should be a plug and play drop in to make all the pieces work. It came from a '12 Touring Mazda2 butttt I didn't foresee this problem; my dang airbag doesn't fit!!!! All the work leading up to this and I am stumped by such a silly problem. I had pulled the wheel and got everything ready for the swap but the trim at the top of the touring wheel prohibits the airbag/horn from falling onto the wheel and operating properly. So my initial thoughts, A. Dremel.. would you think cutting the silver trim to roughly the same size (eyeballing the best I can) would solve the issue? or B. try to find some sort of steering wheel housing to fit the '13 air bag to the '12 wheel? C. Sell this wheel and buy, what? Super disappointed right now because I thought for sure I'd have cruise and audio for the commute in tomorrow. Thoughts or ideas to get up and running?
Hi, Not related but wondered how easy or difficult it is to remove the steering wheel on these without accidentally deploying the airbag? Having some steering wheel/alignment issues and considering doing a retro adjustment
Were you able to get this working? I am looking to purchase a touring steering wheel online and swap out my sport so i can have cruise control but i really want to know if it's as simple as buying a $50 FORScan device to change the hex values on the chip to enable the cruise control feature once I swap out the wheel.
I got the forscan cable and software after doing this same process. So far I have done the wheel swap, the volume and audio controls work with no changes needed, I did have to change the config using Forscan after verifying the rest of the system was in place. You will need the touring model wheel and the touring model air bag. The part number for the touring air bag will start with DR62. The base model starts with DR61. YOU WILL NEED THE DR62. Attempting to modify the plastic on the DR61 is (a) inherently dangerous, using a dremel or trying to cut it and applying the wrong pressure can cause the airbag to detonate, and (b) it just looks tacky having a cutup plastic on the wheel.
