water leaks
Old Nov 1, 2006 | 10:29 PM
sunderam08's Avatar
Default water leaks
Hey guys,
I bought a new mazda 6i GT last month. I have noticed water leaks when i park my car. I dont think its coolant... it was clear and seemed like water...any comments on wats happening. Its a new car!
thanks
Old Nov 2, 2006 | 03:02 AM
rx4to6's Avatar
Default RE: water leaks
water/fluid leaking into the car or under the car? After using air Cond.? If parked on a slope, front up or back up?
Old Nov 2, 2006 | 04:10 AM
sunderam08's Avatar
under the car..front right side . i didnt park it on a slope. i checked the water level for the wipers it seemed low. i had used the ac when the car was running.
Old Nov 2, 2006 | 06:14 AM
everythingzen's Avatar
sounds like its just from your a/c...no worries but you might want to call up your dealer and run it by the service guy over the phone......
[IMG]local://upfiles/2802/2D505F170C724E1499A787127FA0266A.jpg[/IMG]
Old Nov 2, 2006 | 02:20 PM
sstlaure's Avatar
Front right side is the AC condensor. If its green (or orange) and sticky, then it would be coolant.
My wife's 6 does the same thing (as does my 3)
Old Nov 2, 2006 | 05:12 PM
sunderam08's Avatar
Is that normal?? I have not seen that before
Old Nov 2, 2006 | 05:45 PM
sstlaure's Avatar
Every vehicle I have every owned (and that's a lot) drips water off of the AC condensor when the AC has been running (It beads up on the outside and drips off) It's completely harmless & normal.
Old Nov 3, 2006 | 02:35 AM
rx4to6's Avatar
That sounds like the water from the a/c. So nothing to worry. To avoid this dripping and to prolong the life of a/c core in the dash, a mechanic has recommend that: a few minutes before the end of your driving trip, turn off the a/c but keep the fan running. This will keep the core dry to prevent corrosion and no dripping when you park.
Old Nov 3, 2006 | 01:05 PM
sunderam08's Avatar
Thanks guys,
I will contact my mechanic and check with him anyways.... I will keep you posted about any latest developments.
Have fun driving
Old Nov 24, 2006 | 03:48 PM
davidteachey's Avatar
Definitely sounds like a/c condensation...a normal and expected thing, no worries. Cheers,
David
Joe Rodriguez
Aug 29, 2012 05:34 PM
joe morreale
May 10, 2009 01:43 PM
MtechTellsTruth
Mar 4, 2008 10:31 PM
mazdakorey
Jun 6, 2007 10:43 PM
AmberRocks
Nov 4, 2006 03:06 AM
