Oil leaks into one of my sparkplugs
Old Oct 6, 2006 | 11:34 AM
AmberRocks's Avatar
Default Oil leaks into one of my sparkplugs
I have a spark plug that has oil leaking into it, would this just be a simple O ring or a whole gasket, or seal?
And If I fix it would I notice a diffrence in the way the car runs?
Old Oct 6, 2006 | 11:28 PM
bkey71's Avatar
Default RE: Oil leaks into one of my sparkplugs
Are you working on a 4 cyl engine with the spark plugs in the center of the valve cover? If you are the valve cover gasket needs to be replaced which is an easy job to do. The valve cover gasket set should come with the four rings that seal the spark plug holes.
Old Nov 4, 2006 | 03:06 AM
mazzfan's Avatar
Oil leak in the spark plug can cause the coil to fail/short. Having a new valve cover gasket or new o-rings can isolate the direct-ignition stalks and spark plugs from the oil in the valve cover area.
Big Bopper
Jan 26, 2014 08:49 AM
Brett Elliott
Nov 24, 2013 05:07 PM
mazdamom13
May 4, 2010 11:50 PM
mzlr
Nov 17, 2008 10:45 PM
MtechTellsTruth
Mar 4, 2008 10:31 PM
