vibration @ 55-65mph
Old Mar 19, 2007 | 03:50 PM
parkmazdajon's Avatar
Default vibration @ 55-65mph
Has anyone had a similar problem with a vibration at 55-65 mph. It happens if you are not on the throttle. It is not the tires, I heard it could be driveshaft or flywheel. Just wondering if anyone has had this problem corrected.
Old Mar 19, 2007 | 06:34 PM
MrSpike118's Avatar
Default RE: vibration @ 55-65mph
I did, and I had the tires balanced and aligned and it was fine. How are you sure it is not the tires?
Old Mar 19, 2007 | 07:39 PM
Positive, started when I bought the car brand new.
Old Mar 19, 2007 | 07:43 PM
Stealth523's Avatar
I had the same problem and it was the tires. I took it the dealer and had them check it out and they said everything was fine then I had a private mechanic look at it and he fixed it. He said the counter weights on the rims were off....therefore the tires weren't balanced.
Old Mar 19, 2007 | 10:40 PM
This is common on the 3, but usually @ 50-55.[/align]Mazda came up w/a TSB for a replacement engine mount. I haven't tried it, but instead replaced w/an AWR 70 durometer mount which has vibration to spare at other speeds and idle.[/align]Do you have the 2.3, or the V6? Auto or stick? [/align]Have you checked the condition of your engine mounts? Could be you've had a bad one from day one!![/align][/align][/align]
Old Jun 2, 2021 | 05:30 PM
Phil Meakins's Avatar
https://www.vehicle-recall.co.uk/recall/R/2019/187
Old Jun 6, 2022 | 02:49 AM
Ant1972's Avatar
I'm having vibration issues with my brand new Mazda 6 when it hits 80kmph. I was told today there is a known issue with the Cylinder Deactivation System, which kicks in around 80kmph. My car is currently with the dealership while they fit a "part" to hopefully resolve the issue. They haven't yet told me what the part is to fix the problem. I will be test driving it again tomorrow and if the issue persist I'll be taking it straight back.
crmx0312
Nov 20, 2005 11:30 AM
bratan
Nov 10, 2005 04:48 PM
guyonearth
Jul 15, 2005 03:34 PM
alanis
Jun 8, 2005 11:37 PM
MsJBody
May 8, 2005 11:50 AM
