'91 929S Low speed vibration
Old Jun 12, 2005 | 02:36 AM
guyonearth's Avatar
Default '91 929S Low speed vibration
My car is experiencing a low speed vibration at about 15 mph. It is very low frequency, almost like a shudder or wobble, and disappears quickly. I have checked the u-joints, center bearing cushion, CV shafts, and various mountings...nothing appears loose. The trans is not slipping. Feathering the throttle or pushing it harder reduces this effect, i.e. the quicker you get past this speed the quicker it is gone. I haven't noticed anything else strange. Could this be coming from the differential? I'm not sure if this is a limited slip unit or not. I am open to any ideas.
[IMG]local://upfiles/996/3C8A1EDBE2FC4C9793B4AE772D80BB9F.jpg[/IMG]
Old Jun 12, 2005 | 04:35 AM
guyonearth's Avatar
Default RE: '91 929S Low speed vibration
Bump
Old Jun 15, 2005 | 09:17 PM
gtxtreme's Avatar
Have you checked the inner cv joint when worn there can vibrate, mostly when
just starting from a stop. Check both output shaft at the diff, for play in and out. When you said, you checked the u-joints did you remove the driveshaft
to rotate each joint. Often if you just check by trying to twist the joint for freeplay while in the car there'll seem ok. The best test is to remove the shaft,
if you have a worn joint it feel as if one spot is worn flat or notched.
Old Jun 16, 2005 | 03:36 AM
blueman's Avatar
Balance and rotate tires. Unbalanced tires only shimmy at certain speeds.
Old Jun 16, 2005 | 03:25 PM
bdmazda's Avatar
hear hear blueman, it sounds to be most definately a balance or rotation problem. 99% of shaking or wobbling in steering or general comes from improperly balanced tires, easy 20 dollar fix at walmart or local tire repair shop.
Old Jun 20, 2005 | 03:15 AM
guyonearth's Avatar
Its actually a transmission shudder, it seems. Adding a friction modifier didn't eliminate it but it reduce it signifigantly. I doesn't seem to do it when the car is cold, only after it warms up.
Old Jun 20, 2005 | 03:17 AM
guyonearth's Avatar
Old Jul 15, 2005 | 03:34 PM
DLMiner's Avatar
I had the same problem, but it was a tire out of round. Once I replaced the tire the vibration disappeared.
Now since you said it was a tranny shudder? Here's a thought, perhaps your driveline is slightly misaligned.
AndreaM
Sep 14, 2010 02:23 PM
Seanace1
Jun 3, 2010 10:21 PM
Mr. Left
Oct 21, 2009 01:50 PM
kingkleks
Apr 14, 2008 12:52 AM
yamaha30
Feb 26, 2007 11:42 PM
