Help needed...
Old May 3, 2007 | 11:48 PM
Express's Avatar
Default Help needed...
Recently bought a Mazda6 2004, love the car, my first Mazda... One problem, can anyone help. When i turn the wheel to the left, not slighty but let's say to make a uturn. There's a slight knock.. Took it to the dealer today, they checked and could not find anything, anyone have any ideas or simular problems..... Much appreciated.
Old May 4, 2007 | 10:52 AM
davidteachey's Avatar
Default RE: Help needed...
How many miles on your car? I ask that because it sounds symptomatic of a cv joint beginning to fail. If your car has higher-than-typical miles for its age, that's my first suspicion. Write back and tell us how many miles on your car. And when you DO get a firm diagnosis, please report back! Cheers,
David
Old May 4, 2007 | 06:43 PM
Express's Avatar
The car has 74000 kms. Thanks for the help.
Old May 7, 2007 | 07:40 PM
Express's Avatar
Well car was at dealer all day today, and they can still not find the problem....ughh[:@]
Old May 7, 2007 | 08:58 PM
sstlaure's Avatar
Do they hear the noise?Does this only happen at full steering lock? If it's loud enough to hear, you should put it up on jack stands in the front and crawl under the car. Have someone get the noise to repeat over and over (go back/forth over the point where the noise occurs)
You might be able to actually see something moving at the same time as the noise. I've found odd clunks that way before.
Old May 8, 2007 | 11:07 AM
Well, 74000 kms seems a bit premature for cv joints to fail. Have that checked, but the fact that your car has reasonable miles for its age tends to NOT point to a failing cv joint.
David
Old May 8, 2007 | 12:13 PM
sstlaure's Avatar
That depends on the condition of the boots that cover the CV...If the boot gets damaged (many ways they can get damaged), then the grease inside the CV will get contaminated and you will have premature failure.
You want to specifically watch the steering rack (shouldn't move at all) and the tie-rod ends when you are moving the wheel back/forth. If it's clunking, something must be loose and either creates the noise against the bolt that secures the component, or it is hitting an adjacent component.
Old May 8, 2007 | 11:48 PM
Express's Avatar
Well car came out of dealer today, wen't for a drive with the mecanic, and surprise surprise it did not make the noise.. but if it comes back i will take it back..i told them about the cv joint and they said it was good..
Old May 9, 2007 | 09:54 PM
mazda1106's Avatar
this might help you when you go to he dealer
TSB: 06-001/07
2003-2007 MAZDA6 - UNUSUAL NOISE FROM STEERING SHAFT WHEN TURNING STEERING WHEEL
APPLICABLE MODEL(S)/VINS
2003 - 2007 Mazda6
DESCRIPTION
On some vehicles, the steering shaft may make an unusual clunk noise during acceleration while the steering wheel is turned. The intermediate shaft splines in the steering column may be lacking lubrication and causing the clunk noise.
Customers having this concern should have their vehicle repaired using the following repair procedure.
REPAIR PROCEDURE
NOTE: Before performing this repair procedure, be sure to inform the customer that the new super grease is very effective for noise, but it may change the steering and handling feel of their vehicle. Also, the operation of the telescopic steering (if equipped) may feel slightly heavier after the repair.
1. Verify customer concern by changing steering column angle and length (telescoping only), then attempt to duplicate clunk noise.
WARNING: Do not attempt to adjust the steering column angle or length while driving the vehicle. Be sure to adjust the steering wheel only when the vehicle is stopped as you can lose control of the vehicle if you change the steering tilt or position while driving.
2. Repeat Step 1 two (2) more times using different steering column angles and lengths (telescoping only), then attempt to duplicate clunk noise.
If clunk noise is gone, proceed to Step 3.
If clunk noise is still present, do not proceed with this repair procedure. Troubleshoot other causes of noise according to related sections of the Workshop Manual.
3. For telescopic equipped vehicle: Position steering shaft to most forward position.
4. Remove two (2) push-nuts securing joint cover.
5. Remove joint cover.
6. Remove pinch-bolt securing intermediate shaft.
7. Slide shaft toward A to remove from steering gear.
8. Slide shaft toward B to remove from tube.
9. Wipe all grease off splines.
10. Apply approx. 5 cc of new super grease to splines and inside the tube.
11. Align marks and assemble tube and shaft.
12. Wipe off any extra grease.
13. Fit intermediate shaft to steering gear and tighten pinch bolt. Tightening torque: 13.8 - 19.5 ft-lbf. (18.8 – 26.5 Nm, 1.9 - 2.7 kgfm)
14. Fit joint cover and reinstall two (2) push-nuts.
15. After reassembly, operate telescopic or tilt steering as follows:
For vehicles equipped with tilt and telescopic: Operate telescopic three (3) times from front to rear. Operate tilt three (3) times from top to bottom, then return to original position.
For vehicles equipped with tilt only: Operate tilt three (3) times from top to bottom, then return to original position.
16. Verify repair.
PART(S) INFORMATION
Part Number
Description
Qty.
Notes
0000-77-230E-01
Super Grease
1 oz. tube will repair 2 - 3 vehicles
WARRANTY INFORMATION
NOTE:
This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
Additional diagnostic time cannot be claimed for this repair.
Warranty Type
A
Symptom Code
82
Damage Code
91
Part Number Main Cause
5555-07-008A
Quantity
Operation Number / Labor Hours:
XXC024RX / 0.4 (includes cost of grease)
Back to Top
© 2005 Mazda North American Operations, U.S.A.
Old May 10, 2007 | 04:18 PM
Express's Avatar
That's great, i will print it out and take it to the dealer.. THANK YOU SO MUCH........
I have started to love my Mazda6 again..
VegasDriver
Jan 1, 2007 05:38 PM
cugene
Nov 14, 2006 11:58 PM
xtrigger
Aug 10, 2006 07:02 PM
bhc6
Mar 28, 2006 02:49 PM
