Engine Idle Specs need help, Idel RPM, Idle Vacuum, Timin, Spark plug gap??? basics needed
Engine Idle Specs like the, Idel RPM, Idle Vacuum, Timin, Spark plug gap, all the basic stock setting to have engine run right...mine runs a bit rough.....ill replace wires, plugs and clean all conectors if that dont help ill have to play with timin or what ever ideas you guys might have
okey thanks...i got access to Michall on Demand so im able to find more info that i might need...and btw truck idles good now.........i adjusted the timin (dist cap movin around) and played with idle screw...truck runs alot better
