Help needed with B2600-Hesitation at high speed
Old Mar 5, 2006 | 08:26 PM
bhc6's Avatar
Default Help needed with B2600-Hesitation at high speed
Hey, Hope you guys can help me out.
I've got a 1987 B2600 4X4 that I've owned for over 10 years. It might get about 500-1000 miles a year put on it.
Recently, it has lost a lot of power and hesitates a LOT.
It started causing problems at about 25-35 MPH. After a can of gas treatment and oil treatment, I got it up to 50MPH.
I also cleaned the carb with spray cleaner and pulled the distributor and cleaned off some white chalk from the tabs inside the cap.
The engine will rev all the way to the redline if you let it.....lots of raw power and will accellerate fairly well up until about 50MPH, when it really starts to bog down, hesitate nad acts like it wants to stall.
when I back off the gas, it runs just fine?
It does have trouble going up hills as well. 4 wheel drive still works.
Where do I start to track down my problem?
The plugs, wires and distributor cap are only about 2 years old.
All of the vacuum lines appear to be attached correctly.
There is a Major exhaust lead from where the header conects up into the air intake(hose is gone)
There is a hole in the pipe that runs next to/below that(a LOT of hot air comes out that hole)
Where the exhaust connects to the pipe behind the resonator?(right below the engine) there is no seal at that point, so a lot of exhaust sneaks out there. (2 pipes feed back up to the engine at that point as well.
The engine used to give a lot of blow-by into the air cleaner, but that has reduced, however, when you remove the oil filler cap with the engine running, it tends to spit oil out at you.
PCV valve seems fine (it rattles)
So, is my problem most likely
EGR/Exhaust related
Timing
Carburetor
other?
The truck seems to have a good amount of torque...as when I put it into 4 wheel drive and pull the emergengy brake, the front wheels will pull the card foward easily.
I'm somewhat handy, but don't even know where to start! (I've never seen so many vacuum hoses and EGR pipes in my life!
HELP!
[IMG]local://upfiles/3428/7B249B67EB824785AC68AC8E007C2D7B.jpg[/IMG]
[IMG]local://upfiles/3428/1D31E5246AE043C7A0399CC4CAB85247.jpg[/IMG]
Old Mar 6, 2006 | 02:09 AM
Mazdaboy2600i's Avatar
Default RE: Help needed with B2600-Hesitation at high speed
My Truck (1989 Mazda B2600i) was doing the same thing, it would idle fine, but when i got up to speed, it would act like it did not want to get up and go, i checked my gas tank, it had so much rust in it, that it was clogged up, my lines, and my fuel filter, and pump was dirty, replaced tank (125$$(, fuel pump and filter (150 $$$) blew out lines with air, (free) and put it all back together, never had a problem out of it again.. check gas tank.. might be what it is....
Old Mar 11, 2006 | 01:03 AM
Kyrasis6's Avatar
The rattle check on the PCV valve does not mean its good, I've had them rattle and still be bad. If you have a distributor cap with aluminum terminals (most likely you do) I would replace it with one from NAPA that has brass terminals. I don't know of anywhere else that sells them.
Many people think an exhaust leak doesn't affect performance, even a small exhaust leak can have a huge effect on performance especially under load.
Old Mar 28, 2006 | 02:49 PM
bhc6's Avatar
Thanks...I do believe that it is a combination of the exhaust and gas issue.
I replaced the gas filter and the truck ran at 85 no problem. Still had a lack of power, but that is fairly obvious that it is due to the lack of backpressure due to the exhaust issues.
The engine did pressure test equally at about 145 pounds of pressure per cylinder.
Thanks!
Fireman27
Jan 10, 2012 02:30 PM
westvilleguy
Oct 31, 2009 11:05 AM
Handles
May 14, 2007 01:50 PM
rbailey644
May 17, 2006 09:54 PM
bhc6
Mar 4, 2006 10:59 PM
