Coolant fluid.
Old Apr 7, 2006 | 04:19 AM
mazda guy's Avatar
Default Coolant fluid.
In my 6 and in my parents 6, the coolant fluid is right at the low mark. Is this any cause for concern?
Old Apr 8, 2006 | 01:09 PM
mazda guy's Avatar
Default RE: Coolant fluid.
any ideas?
Old Apr 8, 2006 | 02:30 PM
Alamo777's Avatar
As long as your reserve resevoir is not empty, I would not worry. Remember, fluids, like gases take up different amounts of space when they are hot or cold ... so if the weather has been cooler in your area lately, it would make sense that the coolant level would show a little lower in the tank.
It is recommended that the level be between the low mark, and the max mark when the car is parked and cool (I.E. not running). So if you're worried about it, top off the tank with a 50/50 mix of distilled water and coolant. Just make sure you use the correct coolant.
Old Apr 8, 2006 | 07:01 PM
MrSpike118's Avatar
Exactly. Depends if the car is cold or hot. The hotter it is the higher the fluid level will be obviously...Depends on that. If it is cold and it is near low I wouldn't worry at all.
Old Apr 9, 2006 | 02:37 PM
the_gray_mazda6's Avatar
ORIGINAL: MrSpike118
couldn't have said it any better myself.... he is correct!
Old Apr 9, 2006 | 08:20 PM
MrSpike118's Avatar
Well I appreciate it gray mazda!
Old Apr 10, 2006 | 08:24 PM
babyhuey's Avatar
Don't forget too that coolant is 1/2 antifreeze and 1/2 water. What does water do, especially when hot?
Correct answer. It evaporates. At least I think I learned that in chemistry but then maybe I was snoozin'
Old Apr 10, 2006 | 10:44 PM
haha, anytime man
Jmarcin
Jul 9, 2014 07:09 AM
oldzoomer
Apr 14, 2011 04:16 AM
Stevoh
Jun 21, 2010 03:17 AM
mazda guy
Nov 12, 2005 03:33 AM
