Alloy wheels 16" offset
Old Oct 26, 2007 | 08:42 AM
nadajoey's Avatar
Default Alloy wheels 16" offset
Hello, just bought a 2007 Mazda 6 Wagon and I want to put 16" winter tires. (205/60/16). I will put on some alloys wheels and I was proposed a mag with a 45mm offset. Is this good?
thank you
Old Oct 26, 2007 | 10:03 AM
sstlaure's Avatar
Default RE: Alloy wheels 16" offset
Stock size is 17x7 w/60mm offset. What width is the wheel being proposed? 45mm is getting on the edge of hitting the fender lip depending on the width of the wheel.
FWIW...I run snow tires in a 205/50R17 on my stock Mazda6 wheels and they work great. If you are buying new wheels, but some nice summer wheels and run the stockers in the winter....just my .02
Old Oct 26, 2007 | 10:07 AM
nadajoey's Avatar
they are 16x7 (45mm offset) to fit my winter tires 205/60/16. Should I be alright?
(I love the stock mags on the 07 Mazda, 18inches, worth keeping for the summer) but a good suggestion...
Old Oct 26, 2007 | 01:04 PM
sstlaure's Avatar
I didn't realize you have the 18's stock.
That would be a close fit...I'd go to a store and have one mounted up. Check it front and rear.
In the rear, the outer edge of the tire would come into contact with the inner edge of the wheelwell lip
In the front, check for clearance with the tires turned (both directions) at the front and rear of the tires (3 and 9 o'clock if you are looking at the tires.)
Old Nov 7, 2007 | 05:36 PM
nadajoey's Avatar
is there a website I can go to check acceptable offsets.
thanks
Old Nov 7, 2007 | 05:56 PM
CKeffer's Avatar
Closest thing I can give you to something like that is an offset calculator, it'll tell you the difference in where the wheel has been shifted due to the change in width/offset.
http://www.1010tires.com/WheelOffsetCalculator.asp
Craig
Feb 25, 2019 10:23 PM
triplet man
Aug 14, 2010 05:23 PM
gjt101
Jun 23, 2008 02:58 PM
D9ly
Sep 16, 2006 05:47 PM
maz3sport
May 2, 2005 10:04 AM
