Airbag problem
Old Oct 21, 2012 | 07:10 AM
Gmes's Avatar
Default Airbag problem
My airbag lamp is flashing. On mye 2009 mazda 6 2.2 diesel. 1 long then follows 8 short flashes
what does the code? what rights one error,? thanks
Old Oct 31, 2012 | 03:34 AM
I think 18 relates to the passengers seat side airbag. 1st thing to do is disconnect the battery. Unplug the Yellow wiring connector under the seat, make sure its undamaged and clean. Plug it back together, reconnect the battery and go from there. Its a fairly common problem on the 08-12 Mazda 6.
Old Nov 12, 2012 | 08:24 PM
GSXR1000's Avatar
Did you resolved your issue? Try reaching under the passenger seat and push down slightly on the tab supporting the plug. Then turn ignition off then back on. Mine does this sometimes when I move the seat after adjusting the tab up or down then it works.
Old Nov 14, 2012 | 11:42 AM
Gmes's Avatar
Default Hi
First I want to say sorry for the late feedback.
Was at a dealer. them cleaned connectors under the seat. It could not be better. So I told them to skjekke the airbag light bulb that lights up when you turn off the passenger airbag.
And it turned out it was dead, and there have been a short circuit fuse had gone so well. .
Replaced bulb and fuse, and has worked since then ..
Old Sep 24, 2014 | 11:12 AM
Julmust's Avatar
Replaced bulb and fuse you wrote, what fuse?
Cant find any fuses in the main or the fusebox on the left side, marked airbag
liestle
Sep 19, 2013 09:12 AM
JesperPil
Feb 16, 2011 07:50 AM
damoitfc
Apr 1, 2008 09:08 PM
lightnix
Nov 7, 2005 10:27 PM
jjalilvand
Oct 21, 2004 05:50 PM
