2010 AT/Engine problem - should I do this....
Old Jun 29, 2017 | 09:25 AM
bcoffey's Avatar
Default 2010 AT/Engine problem - should I do this....
My 2010 Mazda6 has a leak and I'm out of AT fluid - the yellow AT warning light is on since yesterday and the engine light just came on as I drove it a mile to where i commute to work, and some smoke was coming out of the AT dipstick when I checked under the hood. On the drive the car wouldn't shift gears and I was revving about 4k RPM to go 20, 25 MPH.
My question is: can I add transmission fluid to it to get me home and to my mechanic, about 4 miles total, without harming the vehicle more or should I get it towed?
If I can add the fluid - where do I do it-thru the dipstick tube?
Old Jun 29, 2017 | 09:41 AM
shipo's Avatar
Get the correct Mazda approved ATF and add it; sounds like you're down at least a quart for the transmission to be acting as it does. If I'm not mistaken, it is added for your model year via the dipstick tube, that said, you will most likely need a long thin funnel to do the job. Might be simpler/better/faster/cheaper to have the car towed as you're going to need to have work done on it either way.
Old Jun 29, 2017 | 09:52 AM
bcoffey's Avatar
Thanks for your response. I'm weighing be able to get home faster to relieve a babysitter and figured I could run to gas station next door. But yeah, probably should just get it towed.
Old Jun 29, 2017 | 09:57 AM
shipo's Avatar
Probably a good call as it is highly unlikely the gas station will have the correct ATF for your transmission.
Old Jun 30, 2017 | 05:23 AM
Driving a automatic with low ATF level can easily burn out the clutches resulting in a big rebuild bill.
Old Jul 15, 2017 | 03:51 PM
mazdalief's Avatar
why would you drive ANYWHERE with the atf light on? are you out of your mind?
CHojo
Aug 26, 2009 05:56 AM
lizzhodges
Apr 1, 2008 03:25 PM
2.0Mazda08
Feb 14, 2008 06:57 PM
