No brakes after hitting a bump
Old May 18, 2023 | 07:41 AM
Phxrly1313's Avatar
Default No brakes after hitting a bump
Three days ago I hit a pothole and hit my brakes. Every since my pedal is going all the way to the floor. I can’t be behind any vehicle really in case I need to stop. Ideas about what’s going on?
Old May 18, 2023 | 12:55 PM
Subperson's Avatar
Do you have any brake fluid left? I suppose if the hole was huge it could of damaged a brake line and the fluid ran out?
Old May 18, 2023 | 02:19 PM
Did I read that correctly..... damage to brake system , still driving but making allowances so he can stop without hitting others on the road?
I see the state of residency, is there a joke there somewhere? LOL.
Old Aug 19, 2023 | 10:21 AM
mazda5fixer's Avatar
I had very similar problem. I hit a drop of on a milling and paving road and lost half the level on my brake pedal. If I let off the pedal and push again it feels normal. Going to check it out this morning. I will check for codes first and then put it on some ramps.
Old Oct 17, 2023 | 09:47 PM
Default Large bump and poor brakes
I finally got ours repaired. I put in a new Master Cylinder but I don't really know if it was bad. Today I got an ANCEL OBDII tester on it and used the Autobleed function for the ABS. Works like new again. That was somehow effected by the large bump.
RobertG314
May 10, 2021 10:01 PM
planetm
Jul 10, 2011 08:46 AM
taxie75
Oct 18, 2008 04:15 AM
thedfo
Jan 24, 2008 09:21 AM
