Trunk Cable
Old Jan 18, 2007 | 12:15 AM
wakeboarddude's Avatar
Default Trunk Cable
The latch to open my trunk from inside my car doesn't work anymore. It feels like the cable still has tension but when i pull it it won't open. Can someone help me to see if i can access the cable or something.
Old Jan 18, 2007 | 12:53 AM
dentinger's Avatar
Default RE: Trunk Cable
the trunk cable is also part of the gas door release cable.
so you have to replace both, unfortunately
it's pretty east tho, you just have to find where the cable runs, undo the clips if there is any, replace the cable, and redo the clips....
its actually quite simple....
im pretty sure the cable just hooks into place where the trunk/gas door release is....
at most you'll have to remove some carpeting....or just move it out of the way....you might need some new zip ties, i dont know....
make sure you have the new cable before you start (im pretty sure you can order one thru mazda
Old Jan 19, 2007 | 04:12 PM
icspots's Avatar
Are you still under warranty? If so then this sounds like something that should be covered.
Old Jan 19, 2007 | 05:46 PM
babyhuey's Avatar
Try checking to make sure the valet lockout is not switched on. Sometimes gets accidently bumped and you may not even realize you have this function. Yellow button thingy on the right side of trunk latch is the valet lockout.
[IMG]local://upfiles/1377/DC7E47EFED474138BC4C61B15ED28239.jpg[/IMG]
If button is in this position you can open the trunk from inside.
[IMG]local://upfiles/1377/3F93C7409F0546A8BE84AF5A7F33DC73.jpg[/IMG]
If buttonis in this position then inside release is not operable.
Old Jan 22, 2007 | 03:06 AM
Wow!! that was it. I had no idea we had that feature. Thats pretty neat...Thanks so much for the help!!
Marjnal
Jun 1, 2011 06:36 PM
pattyd814
Jun 27, 2009 08:35 AM
hope
Nov 28, 2006 08:58 AM
samsfanny
Oct 10, 2005 11:26 PM
ginman999
Jun 27, 2005 01:34 AM
